Show distance between vias
Will version 4 be adding the distance between vias like was in version 3. This is very helpfule to plan fuel/meal stops when creating a route.
Kev450 has reacted to this post.
Kev450
No... only distance between stops. But I am planning to add something else that will help you see the distance along the route during planning.
Kev450
OK. My workaround is to covert all vias to stops before making any stops to get the calulation and then converting them back to vias and finding my stops from there. Just an extra step  that I need to remember if I have already made stops in the route.
Thanks for all your hard work.
Even if you already made stops you can still do that. Use the "convert all vias to stops" function (under the 'more' button)... check your route timeline. And then use the "undo" button to get your vias back.
I’d really like to see the distance and travel time between vias come back! I was missing it as soon as it was removed.. 😞
Sorry Kev. This is out of my control. The new routing framework does not provide distance and time between via points. Only for stops.
As mentioned, I'm planning to add another feature that allows you to see the distance (and later time) along the route during planning (so you can plan for fuel stops, lunch stops, etc. based on that distance/duration).
