Sharing routes with Scenic community
Quote from Roelof on 29.05.2023, 03:24Hi,
It's probably very obvious but I've been looking for over half an hour to share my riden routes with the comunnity.
I've been to Norway and would like to share my routes so that if anyone decides to do "ontdek routes" they can find the ones I've riden. However I cannot find anywhere the button which makes this possible.Anyone? FAQ didn't help me either.
Quote from Guido on 29.05.2023, 05:19Hi Roelof,
Select the route from your ‘Routes’ list and then use this button to change it from private to public.
When you do that, other users can find this route through the 'Discover Routes' feature and add it to their own route list:
By filtering on user name the search for your routes will be easy. Of course, the consequence of making your routes public is that every Scenic user can potentially find and use this route.
If you want don't want to make your route public, but do want to share it with a bunch of your friends/riding buddies, have a look here: https://scenic.app/help/sharing-routes-rides/
Hi Roelof,
Quote from Guido on 21.07.2023, 05:44The share button is there on Mac too. Scroll/drag down while mouse-pointer is NOT on the map, but above (otherwise it will move the map)
Quote from TotalEgal on 21.07.2023, 12:07Found it. Thank you for showing it. Please allow to comment, that that solution is not the most intuitive solution possible. Please consider a more obvious way to get there.
Thanks in advance
Thanks in advance
