Guido on 10.06.2023, 05:22
You can’t share locations as you can share routes and rides at the moment (https://scenic.app/help/sharing-routes-rides/). But you can share the coordinate of a location. Simply select the location from your location list and then use the charge button. Also, in Settings > Finetuning, you can turn on ‘coordinates in callout bubble’. This will add the raw coordinates (incl a ‘copy’ button) to callout bubbles (the bubbles y that appear when tapping on a waypoint).
AstridM has reacted to this post.
