Sharing GPX Files
#1 · 26.01.2022, 18:15
Quote from Scott 1977 on 26.01.2022, 18:15I have made a few routes using scenic which is a fantastic app by the way, but I was wondering if I can share my GPX somewhere and if I can see anyone else’s, maybe like a library or something like that to download from and share.?
Click for thumbs down.0Click for thumbs up.0
#2 · 26.01.2022, 18:26
Quote from Guido on 26.01.2022, 18:26There are three ways to share your routes / GPX:
- Export as GPX and send the GPX to whomever wants it, in whatever way you want. To export the GPX, select the route from your list, and tap the 'export GPX' button below the map preview.
- Create a share link to the route: select route from list and tap 'share' button. A link is generated which you can send to others. When others click the link, a website is opened and from there they can add it to their scenic, download the GPX, etc. Here's more details on how this works: https://scenic.app/help/sharing-routes-rides/
- Make the route public so others can discover it: in the power planner save dialog there is a 'public' switch. When you set that to ON, others can discover it. You can also make a route public after saving: select route from list and tap 'access' (Private) button above the map preview. Change to public. Once that's done, others can discover your route by going to their route list, tapping little '+' button and selecting 'discover routes'.
