Sharing and saving: no file
Hi
Just switched to the iPhone 15. Strangely enough, the gpx export no longer works: the file does not seem to be available either when saving locally or sharing the file.
Whats different? Any settings I never used before?
Thanks Tom
Hi Tom,
Not sure. This is an alert from the files app. How did you get to this screen? What actions did you do in Scenic for this to appear? Are you able to export and choose other apps, like, for example, email?
Hallo,
nur zur Info, bei mir funktioniert der GPX Export auf iPhone 15 ohne Probleme.
Beste Grüße
Tombal has reacted to this post.
Tombal
Hi Guido
It works fine with other navigation apps like Osmand, with Whatsapp and Email, but not saving in iCloud and sharing with Signal.
Best regards
Tom
Hi Tom,
This doesn't seem like a Scenic issue to be honest. What options are you choosing in the export panel? "Save to files"?
What happens if you choose another folder (like a local folder)?
Perhaps there is something wrong with your iCloud settings, or you need to re-enter your iCloud password?
Hi Guido
Indeed, probably it's not Scenic: yes, I choose 'save to files'. Unlike on the icloud drive, the file now seems to be saved locally: click on it and it opens in Navigation app.
However, when I want to share it, only this link is sent...best regards
Tom
Hi Tom,
There must be something wrong with your iCloud Drive. Perhaps you need to re-login, or perhaps your iCloud Drive is full, or, if it’s a company phone, there might be a policy preventing saving files. Perhaps try googling the error message.
If you want to share a link to the route with someone else, try the “share” button in Scenic (in stead of the Export GPX button). This will generate a link to the route which others can open. Here’s a help article with short video on that: https://scenic.app/help/sharing-routes-rides/
Tombal
Thank you Guido, I'll try...
