Share Round Trip Route
Quote from Deleted user on 03.10.2023, 09:45Hi,
I'm want to generate a round trip route and share the GPX with the people I'm riding with.
Is there a way to do this?
Many thanks
Many thanks
Quote from Guido on 03.10.2023, 10:16Hi Billy,
Yes, go to the power planner (through the side menu). Drop your start point wherever you want the round trip to start. Then choose 'round trip' from the top toolbar. The round trip will be generated. You can move/change/remove some via points afterwards to make adjustments to the route if you want. Once done, save the route.
Then, select the route from your route list (through side menu again), and at the bottom you'll see a "share" button.
Hi Billy,
