Share folder instead of individual routes
Quote from Mkoetsier on 28.02.2022, 14:17Hi Guido,
Thanks for the great app! I have a suggestion for you. I’m making my route for the next holiday, but is it possible to share a whole folder instead of separate gpx routes? It makes it easier to share the routes with friends if i van share the folder and not sent all the seperate gpx files
Quote from Guido on 28.02.2022, 14:20Not yet.. I'll add it to the list.
Just a side note: You might want to consider sharing the URL in stead of the GPX files. (Use the 'Share' button in stead of the 'Export GPX' button). Then you don't have to send megabytes over email. Only the links. Your friend can click the URL and from the webpage that opens in their browser they can see a map of the route. Also they can download the GPX from there, or alternatively, if they have Scenic, add it directly to their Scenic account without any import actions at all.
Here's how this works: https://scenic.app/help/sharing-routes-rides/
Quote from Binwaa on 25.03.2022, 22:55This is a really nice feature, but…
the names displayed on the map are in local language. Meaning that here in Thailand all the names of towns and streets are in Thai. This is not the case while using the Scenic app.
example can be found by clicking on next URL :
https://scenicapp.space/viewRoute.php?rid=zxIxqrei
can this be avoided to keep English names ? Based on the maps language defined in Scenic, the link could be something like :
https://scenicapp.space/viewRoute.php?rid=zxIxqrei&language=en
it is evident that the server needs to be able to interpret he extra parameter to be used for generating the map.
Quote from Guido on 26.03.2022, 08:39can this be avoided to keep English names ?
Currently the web link uses a different map provider than the app. Once I have the chance to expand the WebApp I will also switch the maps to HERE maps, and the problem will be gone
