Share a folder or multiple routes
Quote from Dae on 18.08.2024, 01:45Hi,
My wife and I both use Scenic. What usually happens is that one of us does the route planning (normally her) and then we share the routes with the other person. We always put all routes related to a tour in its own folder.
What we’d like to see is an ability to select a folder and have a share button that either shares the folder explicitly or shares all the routes within the folder. This would be much better than the current situation of having to select each route individually and share it. An alternative would be to allow multiple routes to be selected when sharing. It would make the whole process more efficient, especially when you sometimes have the issue that you can’t see the navigate/share buttons below the route overview so have to mess around trying to get the screen to scroll and reveal the buttons.
Quote from Mex on 18.08.2024, 03:11Hi Dae.
As a workaround you could login to Scenic with the same account as you do it for e.g. with ipad and iPhone on both phones.
So all routes and rides should sync automatically.While you ride alone sign in with your own account.
May work.
Ride safe, Mex
Hi Dae.
May work.
Ride safe, Mex
Quote from Dae on 18.08.2024, 03:13That would mess up riding statistics etc. and probably be far more inconvenient than sharing routes one at a time.
Quote from Mex on 18.08.2024, 03:51Hi Dae.
Your right stats would mess up. I share our routes daily on longer trips, so my buddies decide to use it at calimoto or scenic. Not a big thing just sent by mail,in case one has no iphone, and they may open Scenic or import the gpx.file.
Kind regards, Mex
Hi Dae.
Kind regards, Mex
Quote from Guido on 18.08.2024, 06:00It’s on the feature request list. Currently working on a big update for October. If I have time I will add it there. If not, it will be added later.
Meanwhile, the only way sharing one by one. Sorry.
