send several tracks by mail instead of just one
Quote from Middelfrangge on 22.04.2025, 00:49Hi,
I am looking for a function that allows to send e.g. 10 or 15 Tracks at once by mail. Currently with no possibility of merging tracks, I sometimes end up with 3 or 4 tracks per day. After a 10 day ride I have to therfore send roughly 30-40 tracks to my PC (for merging and geotagging of my pictures). Maybe I did not find the function until now but I can only send a track when opening and choose send gpx data……means I have to open up to 40 tracks. Is there a way to select all tracks and finally send them at once?
regards
Thomas
regards
Thomas
Quote from MjK on 22.04.2025, 10:51Hi Thomas,
not that I think this is possible at the moment.
But thinking of your challenge, I by chance stumbled over this https://github.com/locked-fg/gpxmerger a simple script to merge multiple GPX files into one large GPX file.
The Use Case matches quite precisely your scenario:
During holidays, one or more tracks are created for each tour / day. In the end a single GPX Track is required for example to use in Lightroom in order for easy geo tagging or to get an overall map of all tracks. Thus, a single GPX Track should be created from multiple GPX files.
Maybe this helps streamline your process a little bit
Cheers, Markus
Hi Thomas,
Cheers, Markus
Quote from Middelfrangge on 22.04.2025, 11:57Hi Markus,
thanks, I do not have a problem to merge tracks, even if I prefer if it is already merged before sending it. I also have already a software for geotagging. My request would be to select and send more than one track at the same time.
If its not available then this would be a feature request.
Cheers
Thomas
Hi Markus,
Cheers
Thomas
Quote from Guido on 22.04.2025, 15:13Hi @middelfrangge,
I can't add the batch upload very soon. But... if I understand correctly, you are currently stopping your ride to load a new track. This is not necessary. You can load another track while keeping tracking active. To do this: https://scenic.app/forum/topic/merge-recorded-routes-aufgezeichnete-routen-zusammenfugen/#postid-12157
This at least will keep down the number of recorded rides.
Hope that helps.
Hi @middelfrangge,
Hope that helps.
Quote from Middelfrangge on 22.04.2025, 22:51Hi Guido,
thank you. I saw that in another chat that it is possible to switch to another route and thats reduces the number of tracks bu often I still have more than just one. It does work if not using carplay like I do and it does work if I always have a route to follow when switching. When stopping the route and just drive with map I have to stop the navigation and switch on just tracking.
I was hoping such a batch upload would be easy, because even if it is just one track per day t would be 15 mails to send and 15 mails to open on my PC……..
Maybe my request is too specific for the way I deal with tracks.
Thomas
Thomas
Quote from Guido on 23.04.2025, 06:37It does work if not using carplay like I do and it does work if I always have a route to follow when switching. When stopping the route and just drive with map I have to stop the navigation and switch on just tracking.
Simply switch to another app on CarPlay. This will make Scenic active on iPhone and you can “edit route”. You then have full functionality of the power planner available while navigating, including clearing the current route, adding / removing waypoints, creating a new route from scratch, etc. All while the tracking continues. No need to stop the tracking, even on CarPlay.
Batch upload is on the list, but as mentioned it will take a while. Also please consider that when you import, it’s always recommended to check and if necessary make small changes to the route during import. This would not be possible with batch upload.
