Select Vehicle for Saving Recorded Rides
Quote from blackhawk1618 on 15.10.2024, 17:07Hello Guido,
I ride several vehicles and have added them to Scenic with their pictures. But after Scenic 4 upgrade when I save a ride, it always gets assigned to just one vehicle. I then have to go to the recorded ride and manually select the correct vehicle and save it again.
Could you add an option to choose the vehicle before starting a ride, or allow me to select the correct vehicle when saving a ride? Also, could you bring back the vehicle icon on the recorded rides map thumbnail instead of the saved photo? This would make it easier for me to quickly identify which vehicle I used for each ride.
Hello Guido,
Quote from Guido on 15.10.2024, 17:45You can select vehicle when saving. By default it will use the vehicle your last ride was saved with.
I’ll probably change this to the picture slider again in a future version, but for now, the test dropdown works.
In the ride detail view you also see the vehicle as text.
I can add back the picture in the ride list. That’s relative fast to do.
Quote from blackhawk1618 on 16.10.2024, 07:26Thanks Guido.
Could you also bring back the vehicle image for the recorded ride map thumbnail, as it was available in Scenic 3?
In the screenshot from Scenic 3 version.
Thanks Guido.
