Forum breadcrumbs - You are here:Scenic ForumUsing ScenicSecond issue
Second issue
ok, here’s the scenario. I have my two shortcuts set up as play podcast and play audiobook. I press either shortcut button and the shortcut opens and plays but I can’t pause it using the scenic pause button and when I press the pause it opens my apple shortcut menu?  At the moment I’m testing indoors so not connected to the WunderLINQ unit.
Sound like you already setup the previous/next and pause button to control all audio apps, right? (In Settings > Navigation Menu > Playback Control. )
Are the required shortcuts still setup correctly in your shortcuts app? https://scenic.app/help/control-music-playback-for-all-media-apps-not-just-apple-music/
If so, perhaps something changed in the shortcust app. If so, I'll need to look into that.
Thanks Guido, changed it to Apple Music and all is good now.
