Forum breadcrumbs - You are here:Scenic ForumUsing ScenicSearch Results
Search Results
So, in my search results I’m seeing the “Here” results duplicated (2 blocks of 20 results with the same contents), a search button next to google and nothing from the Apple results. Is this a bug, something to do with my settings, or…?
This is "as designed".
HERE has two search engines. The offline engine (searched the offline maps you have installed) and the online engine (searches HERE maps online). There can be differences, depending on your search term and what offline maps you have installed. E.g. if you search Eifeltower, and you don't have the French offline maps installed, the offline engine won't return results.
Next to the two HERE engines, Scenic also searches Apple Maps. Since they use different data, it sometimes happens that HERE doesn't return results and Apple Maps does (or vice versa). Depends on your search term.
Google Search is there for if you still don't get what you are looking for through the othe search engines.
Thanks for the clarification Guido. Appreciate it!
