Scenis shortcuts and Wunderlinq feature suggestion
Quote from idebide on 27.05.2020, 15:40Wunderlich integration is great, thank you!
One thing that would help is if the menu that displays the shortcuts and other options, like "detour", etc., had a circular scrolling behavior. In the current version there does not appear to be an efficient way to get from last to first item by scrolling.
The user shortcuts are in the upper left corner of the screen and the default selection when entering the menu is on "close" which is the last item in the lower right corner. If the scrolling where circular (allow moving from last item to first with one scroll movement) one could select the most used user shortcut without racing to scroll over a dozen items up and left.
I can directly push the button but prefer not to look and peck hoping gloves work.
Quote from Guido on 27.05.2020, 17:25I was actually making changes to the 'nav menu' and can take this into account too for the next update! Thanks for the suggestion.
Quote from Guido on 14.02.2022, 06:18the map already zooms in/out based on speed. This is independent of WunderLINQ though. Or am I misunderstanding your point?
Quote from SpearMen on 15.02.2022, 06:57Quote from Guido on 14.02.2022, 06:18the map already zooms in/out based on speed. This is independent of WunderLINQ though. Or am I misunderstanding your point?
Sorry, I tested it for the first time yesterday and didn't notice a zoom while driving. Possible that I have set something wrong?? Greetings!
I use Scenic on my IPhon 12 Pro mounted on my Honda VFR 1200 XD and know no WunderLinq. Greetings!!
Quote from Guido on 15.02.2022, 07:09In Settings > Navigation & Tracking > Zoom. You can choose between manual and auto. Default is Auto.
Also, you need to be in navigation mode. In other words, you need to have tapped the ‘Record Ride / Start Navigation’ button.
Quote from SpearMen on 15.02.2022, 07:13Quote from Guido on 15.02.2022, 07:09In Settings > Navigation & Tracking > Zoom. You can choose between manual and auto. Default is Auto.
The automatic zoom is set on my Senic. I navigated along a prepared and saved route. I will test it again. Greetings
Quote from Guido on 15.02.2022, 07:23Ok. Let me know if it doesn’t work. Best is to mail me directly or open a separate topic on the forum. This topic is for WunderLINQ related issues. A separate topic will help others will similar questions/issues to better find answers.
Quote from SpearMen on 15.02.2022, 08:01Quote from Guido on 15.02.2022, 07:23Ok. Let me know if it doesn’t work. Best is to mail me directly or open a separate topic on the forum. This topic is for WunderLINQ related issues. A separate topic will help others will similar questions/issues to better find answers.
Yes thank you, I will do that.
