Scenic navigation keeps rerouting my created routes
Quote from sickora on 23.08.2020, 10:55As the title says. It is not every time, but it happens enough and is frustrating. I'll create a route for myself to follow and use navigation for directions. At some point, the navigation directions start to change from what my route is. Today I was following one road for about 35 miles and 20 miles into it Scenic had me turn off, drive some other roads, and get back on. Why does this keep happening? Am I missing a setting?
Quote from Guido on 24.08.2020, 09:28There can be three reasons for this:
1. The route was created with an older version (with older map version) of Scenic. When you select the route for navigation it is recalculated with the maps and routing algorithm of the current version. Usually there is no change in the routing algorithm between version, but I have been doing minor changes between the last 2 versions which could have caused this. I will not make any more changes to this for now.
2. Scenic thinks you deviated from the route. This can sometimes happen even if you are still on route (for example if there is a small deviation in a road location on the map from reality... or the map is not completely up to date. E.g. I've had it happen where a certain highway junction was 'modernised' by the government, moving the roads a little bit, but the map still had the 'old' junction, which resulted in Scenic thinking that I was off route, recalculating to get me back on it.
3. The 'strange loop' was also there when you created the route, but due to zoom levels was hard to detect. In general I recommend to do a final check after creating a route. zoom in quite a bit and then drag the map along the route.Hope this helps/explains. If not or if you have other questions please let me know. Happy to help.
Quote from sickora on 30.08.2020, 07:35Thanks for the reply. I'll definitely check to make sure it wasn't #3. I've had #2 happen a few times, but never enough where I've fallend off the route. Great app, it's made my exploring so much easier.
Quote from windingroad38 on 23.09.2020, 07:54I put my comment below these lines, because I just wanted to start a new thread with exact this question, how to share a route between apps without the problem of having multiple routing-versions due to individual calculating options in each app.
Glad I found this thread before writing and sharing the Link is exactly what I had looked for.
Thank you.
Thank you.
Quote from dasherpr on 29.11.2020, 13:59Hi... I have been using Scenic in Puerto Rico for a while. Generally great, way (way) better than Rever which so many of my BMW club mates use. However, no matter how carefully I plan a route and add via points to the main intersections or ensure I don’t miss anything, in areas with lots of little roads or streets Scenic will often recalculate even though I know I’m on the right road, and send me off on some creative loops. Embarrassing when I have 5 buddies following me! I am going to try the “go back” function instead of automatically figuring out a new route, but it isn’t that I’ve missed a turn; Scenic gets creative even though I haven’t. Frustrating. I guess, like the explanation above, it loses me and then tries to help me. Perhaps you can make this less sensitive?
Quote from Guido on 29.11.2020, 14:16Scenic is indeed sensitive indeed. It could also have to do with inaccurate GPS signal. I can't do anything about this in the short term (as this is being done by the map and routing framework), but in Scenic 3 this will be taken care of, as that will with to a new map and routing provider.
Quote from dasherpr on 20.12.2020, 09:56Guido, yesterday I used Scenic on purpose (even though I knew the route). I planned a ride using Google My Maps and easily had the Scenicapp read it from the link (I LOVE this feature!), and then rode my ride. (Elsewhere, I am reporting on the fact that using Scenic somehow blocks the BMW Connected app from following my ride). Ok. Again, when driving through areas with lots of little secondary roads near each other... Scenic goes crazy. Wants to recalculate, even though I know I'm on the route. Then draws weird loops, even though I carefully went over the Google Maps import and fixed all those. If I were trying out an unexplored route, this would definitely have sent me on all kinds of unwanted detours. I know you know about this; am just underlining how annoying it is.
Thank you for your hard work making it better!
Quote from Guido on 20.12.2020, 11:00I understand this is very annoying. I’m actually not sure why this is happening that much. Would you mind sharing the route with me and, if you remember, indicate where it was rerouting you unnecessarily? Here’s how to create a share link to a route. If you prefer you can send me a direct email through the support link top right (all the way at the bottom).
Quote from dasherpr on 20.12.2020, 11:54Guido, here's the link.
The rerouting was happening between waypoints #9 and #10 the most, if I recall correctly. I know the route, so I just ignored them.
https://scenicapp.space/route/LUFTEYMe
Hope this helps!
Hope this helps!
Quote from Guido on 21.12.2020, 16:18Hmmm. It's quite strange to be honest. This is probably a combination of two things. Can't be sure, but in any case I'm afraid there's nothing I can do about it.
- The map latitude data is slightly off. In other words, the roads, in reality are more up or down than the map indicates. I'm saying latitude / up or down, since the rerouting occurred mostly when the road was "horizontal".
- The matching of the coordinates to the road is not smart enough. It matches the GPS coordinate to the closest road. In my opinion it should take the route into account too, which is seems it doesn't. With even the slightest deviation from the route and it's on a junction it thinks you are on the other road... starting to reroute you
Sorry that I can't solve this now, but Scenic 3 with the new map provider will solve this entirely.
Quote from Ciro on 12.01.2021, 06:08Hi,
not sure if it's connected to this problem but I also think there is an improvement to be made in the routing algorithm.Let's say I am on a relatively "main" road, in the route creation the apps want me to get out of it then back in after 1 or 2 km and I end up passing inside somebody's house :).
I've tried to change the various heuristics like Fast, Effective and so on and it seems it like to do that quite a lot. This is happening both in Italy and in Greece. It's kind of frustrating since the 2/3 km detours are kind of meaningless.
Not sure if there is even a thing, but the algorithm should not leave a road for then coming back to it (unless there is a via point) within some X (10?) km.
Not sure if it makes sense.
I've made a route on the fly and captured a couple of these things. Usually, I go manually to all these detours and put a via on the right side. in light color is the "would like to be" route.
Quote from Guido on 12.01.2021, 09:18Quote from Ciro on January 12, 2021, 06:08Hi,
This is a little bit related to the problem on this forum topic, but not entirely. These 'detours' are due to bad map data. Specifically, road categories being wrong or missing. In essence the map provider categories the main road the same as the detour road (or both are not categorised) (or worse, the detour road as a higher speed category road) resulting in these wrong detours. This is one of the most important reasons why I'm switching to another map provider in Scenic 3. The testing I've done so far have given excellent results so I'm hoping this problem will be almost completely gone with Scenic 3.
Quote from Ciro on 12.01.2021, 10:46I see what you mean. Let's hope for the best and we keep fixing the detours and enjoy the app while riding 🙂
Thanks!!
Thanks!!
Quote from mogan on 28.02.2021, 16:00I am having a lot of problems with scenic trying to divert me off course. On Wednesday I planned a route from Mukilteo to Maple Valley. Most of this was down I405. Scenic kept telling me to get off at several off ramps to get on I405 which I was already on. The return trip it routed me off I405 to the kitsap pennsula way out of my way.
Quote from Guido on 28.02.2021, 17:36Quote from mogan on February 28, 2021, 16:00I am having a lot of problems with scenic trying to divert me off course. On Wednesday I planned a route from Mukilteo to Maple Valley. Most of this was down I405. Scenic kept telling me to get off at several off ramps to get on I405 which I was already on. The return trip it routed me off I405 to the kitsap pennsula way out of my way.
It sounds like it could be a mapping issue. When you planned the route, was it fine? Only during navigation is when it starts rerouting you?
Quote from Guido on 02.03.2021, 12:09Quote from mogan on March 2, 2021, 11:49It was such a simple route that I didn't check the routing.
You shouldn't have to of course. I'll report to the map provider. In any case this will be resolved in Scenic 3 with the new map provider.
Quote from maja on 08.03.2021, 02:05It's great to hear that the routing will improve with changing the map provider in the near future. I experienced this re-routing myself on my last trip where I was driving on a main road and from out of nowhere the app said that it wants a re-calculate the route for no reson. Also, the routing advices are not very helpful sometimes. I had it several times that the voice told me to "make a light left turn" when I needed to only follow the main road and there was no way to make a left turn. I hope this all will improve 🙂
Can you say which map provider it will be?
Thanks, Marc
Thanks, Marc
Quote from Guido on 08.03.2021, 07:33Hi Marc,
Yes, fully understand. These two things will definitely be addressed with the new map- & routing provider, which for now, Inwill keep to myself 🙂.
Hi Marc,
