Forum breadcrumbs - You are here:Scenic ForumUsing ScenicScenic crashes often
The app has been functioning fine (iPhone 12, iOS 18.5)for months but all the sudden, it started to crash every time I either start Planning a route or loading any of my saved routes.
Yes, I have rebooted the phone, unloaded and reinstalled the app. Nothing helps.
Phone has 20Gb of free storage.
Has the app been updated lately? It looks like a bug.
Could be a bug or, more likely, something corrupted in your account. Would you mind sending me a direct email with your Scenic nickname? (Use email button at bottom of help page)
Hello, I am having the same problem, iPhone 16 max, ios 18.5, Scenic v4.21. I tried all of the things the above poster mentioned. Pretty much nothing works, app crashes if I attempt to plan a route, crashes if I try a saved route. I think it will track a route but I don’t use that feature. Is there any fix in sight?
Happy to say, after deleting the app and reinstalling, everything appears to be working normally. I will post again if anything goes sideways.
I have been working with Guido and he found out the cause of the crashes. The new release will have the fix.
Many Thanks for the update!
There is currently (v4.21) still a bug.  When “do not auto close” switch in Settings > Navigation & Tracking is enabled the app crashes frequently. This will be fixed in the next version. Meanwhile if you disable that setting all should work.
