Scenic always crash
Quote from satmax on 04.03.2022, 14:32Every when I try to start Scenic it will be crash. 3th time this year. Only a full deinstall does help. I enable show on map enable all ride folders…
Quote from Guido on 04.03.2022, 14:37How many rides are in the folders? Are you also enabling POI groups? (There is a known issue with big POI groups ( > 1000 POIs). For the moment best not to enable those.
Quote from satmax on 08.03.2022, 02:59I'm only enable "aufgezeichnete Fahrten" (recorded tracks), folder "Fahrtenordner". I found some if this recorded tracks are bad (crash when opening track). I removed this tracks (moved to a folder bad track). But the app still crashes when´I enable 2-3 folders with recorded tracks (~100 tracks).
But the biggest problem is that I have to completely uninstall and reinstall scenic after such a crash. Last weekend I tried 6-7 full deinstall / install... 🙁
It was nice to have a feature, I can start scenic in a save mode (maybe after each crash), where I can change the full settings (also setting show on map).
Quote from Guido on 08.03.2022, 06:38Hi Satmax, yes you are right. I will add such a feature.
Its strange that it crashes though with this relatively small number of rides. I will also take a look at your account to see if there’s anything else wrong with some of your rides that might cause this.
Sorry for the inconvenience!
Quote from Guido on 08.03.2022, 10:23@satmax
I found one more ride in your account that was corrupted. It was the ride named 'Fahrt von 2021-09-20 14:58'. I removed it from your account now, so Scenic shouldn't crash anymore now.For the next update I'll also make sure Scenic won't crash anymore because of these corrupted ride. And I'll add some kind of safe mode, or disable all layers after a crash on start-up.
Apologies for all this. I hope now it's fixed for you. If it still crashes please let me know!
@satmax
Quote from satmax on 15.03.2022, 01:15Thx Guido! BTW: after each reinstall (full remove and install new) I lost all my scenic settings and all my profile pictures (driver and bikes).
I will wait for the next update before I retry to enable my rides... 😉
