Scenic 4 Recorded Rides Missing Date and Time
Hello Guido,
In Scenic 4, the recorded rides are missing the date and time stamp, showing only speed and elevation. It is really important to have the date and time stamp for each recorded ride, as this was available in Scenic 3.
Having the date and time details helps track when each ride took place and provides a clearer picture. It also serves as evidence in case I receive an incorrect traffic fine.
LaszloK
Date and start time is there. Duration (riding time / break time) will be added back in v4.01 (release by end of this week)
Quote from Guido on 09.10.2024, 06:49
I am not referring to the start date and time of the recorded rides.
I am talking about the date and timestamp that appears when you playback the recorded rides, similar to how it worked in version 3 like below.
LaszloK
Ah. I'll add that to the list.
LaszloK
Quote from Guido on 09.10.2024, 10:55
Cheers! Thanks Guido
I upgraded the app to 4.01 version and the date and timestamp for the recorded rides is still not added. It is crucial to have this information for my recorded rides.
Sorry… this was not a priority item for v4.0.1. as I wanted to get that out there before the weekend.  I’ll try and add it in the next update.
Another + 1 for this feature to come back.
Next version:
NickG and blackhawk1618 have reacted to this post.
NickGblackhawk1618
Thanks, Guido.
Will the next version work with my existing recorded rides, and will it display the date and timestamp for those rides?
I still have Scenic 3.66 version installed on my iPad, and when I checked my recent recorded rides, it shows the date and timestamp but I guess from a different timezone.
I recently updated Scenic to version 4.02, and I noticed that the date and timestamp for my recorded rides are now visible. However, the time is displaying as 4 hours ahead of the actual time, as if it’s pulling from a different time zone.
Could you please look into this?
Attaching the screenshot
I checked the code, but can't find anything wrong. Using the same data and your local timezone. My personal rides are also fine.
Is this with all your rides?
I notice this ride has a break time of over 4 hours. Is it possible you started the ride, but only started actually riding 4 hours later? (I admit that would be a weird coincidence).
Yes it's the same data for all my rides. All my recorded ride times are 4 hours ahead of my local timezone.
The break time shown in the screenshot is accurate, as we took an extended break, and at one point, I forgot to resume the ride.
I also tried reinstalling the app, but the issue remains same.
Oops. This is a deeper problem than I expected. Scenic 4 is recording the times wrong. My old (Scenic 3) rides are OK. My Scenic 4 recorded rides have a similar problem. . Will fix for next udpate.
Thanks Guido, all your support and efforts are much appreciated.
Found the issue. It's a timezone thing indeed. It will be fixed in the next update.
Unfortunately, I can't correct this for rides that were (and will be) recorded with Scenic 4 version older than the upcoming update. It's because the timestamps are already stored in the database with the wrong timezone. Sorry.
blackhawk1618 has reacted to this post.
blackhawk1618
I'm glad that I searched for the topic. I also noticed that the timestamp was off. I'm glad that you've got it on your list to fix... Good Luck, and thanks for everything.
--Bobby
