Forum breadcrumbs - You are here:Scenic ForumUsing ScenicScenic 4 issue
Scenic 4 issue
I have traced all my previous scenic 3 routes as suggested. I have noticed that the via stops that were labeled with what each stop was,  is no longer. Most all my stops are labeled as lunch and the  name of the restaurant.  Using scenic 3 I could tap on via point stop and get this information.  After upgrading to scenic 4 none of these stops give  me any information about the stop. Any suggestions to fix this would be appreciated.
thanks
That's strange. Via points never had names, but stops did, and should show.
Ah... now that I'm thinking about it. Maybe this doesn't work in the full screen map view. But it should work in the route editor. (select route, tap 'three dots' button top right, and select edit route.
Let me know how it goes?
