Forum breadcrumbs - You are here:Scenic ForumUsing ScenicScenic 4- export GPX?
I do not see an export GPX button anymore,
is this function removed??.
Da geht weiterhin. Rechts oben die 3 Punkte klicken
Lbnyc has reacted to this post.
Lbnyc
Select route/ride and then the “three dots” button top right.
Lbnyc
Yes. but only individually. for each individual file. about five steps/touches per gpx. with almost 200 recorded journeys, that makes around 1,000 touches. Please provide a general export function for several gpx files at the same time. thanks in advance
