Scenic 4.01 Navigation and GPS Glitches
Hello Guido,
I was out riding today and noticed a couple of issues with the new 4.01 update when using navigation.
First, before starting the ride, I set a destination with two stops along the way. After the first stop, I decided to change my destination to a new one. The navigation worked fine up until I made that change. Once I updated the destination, the directions and road names stopped appearing at the top of the screen. To fix this, I had to stop the ride completely and start a new one with the new destination. I took a screen recording for this issue but not sure how can I share it with you.
Secondly, I accidentally closed the app during the ride. When I reopened it, I was prompted with the Stop / Discard / Resume options. I chose "Resume" to continue, but instead of showing my route, the GPS displayed the "flying crow line" from the starting point on the map. Luckily when I saved the ride at the destination the GPS has  recorded the track correctly.
Could you look into these glitches?
Yes. Thank you for reporting this. The screen recording might be helpful. It’s probably in your photos app. To share a link to it with me, select the video, tap the “box with up arrow” button bottom left, and then select “copy iCloud link”. If you prefer, send me the link through email using the email button at the bottom of the help page.
Thanks Guido, I sent you video iCloud link through email.
Thanks for the video. I watched it. Scenic is not recognizing you are back on the (edited) route and is not giving directions because of that. I’ll have a look. Thanks !
bdwalker1 has reacted to this post.
bdwalker1
I had the same issue as blackhawk1618 several times. In this situation I pressed the „overview“ button and then „close“ and this brought the view back to my route as well as directions and road names showed up again.
I have checked again after upgrading Scenic to version 4.02, and it seems the issues have not been resolved yet.
I have a new screen recording of both issues, let me know if you would like me to share it with you.
I am hoping these issues will be fixed in the next update. Thanks!!
