Scenic 3 Setting Home Location
Guido how do you set Home location. The message says through Side Menu Locations but I just cannot see how this is done.
Hi Peter,
Add a location through search or selecting on the map, and then, once you reach this screen, flip the “home” switch.
Thanks Guido. OK finally found how to do it.
Took me a little to figure this out too.
Maybe one extra callout: If you have multiple home locations and you set the home flag on two different ones only the last one you saved seems to stay. Not a big deal - just good to know. I keep mine as favorites and that works well for most situations.
OK. Thanks guys. I will think of another way to make this more intuitive. Clearly, there is some room for improvement here. Thanks for letting me know.
