Scenic 3 Route Saving After Copy
Hi Guido, I love this App and recommend it to my friends. I've been using the new version since it came out and I think I may have found a bug. Here is what I did and what happened:
  1. Went into one of my route folders and selected a route I had created in Scenic 2. I then duplicated the route and changed a few things (I deleted the original starting point and replaced it with a different starting point and I deleted two waypoints from the original route).
  2. I saved the edited duplicate route in the same folder under a different name.
  3. When I closed the new route, it showed up in my folder together with the original route but both still showed the same image for the thumbnail in the folder and both listed the same milage info even though the edited duplicate route was different. Also, the duplicate route did not have the name I assigned to it, it preserved the original route name and added "(copy)" to it even though I had changed and saved the name.
  4. After a couple of minutes, the new edited route disappeared and could not be found. Only the original route remained.
I tried this operation three times and made sure I was hitting the "Save" button every chance I could but nothing worked. I got the same result each of the three times.
Thanks!
UPDATE: I was able to find my new routes in my favorites folder instead of the folder I started in.
Hi and thanks for the detailed analyses. My apologies for this. I will make sure to fix this in the next update. Hopefully to be released this week.
