Scenic 3 - I cannot find public routes
Been playing with Scenic3.  I usually hate big UI changes to software that I use a lot, but this all seems good and worthwhile. I'm sure I'll be using it without thinking in no time. Really like it.
There's one feature I can no longer find though: the ‘Find Scenic Routes’.   I can no longer find/browse public routes that I've not previously interacted with.
I think Guido has made the UI much cleaner and clearer. I love the changes. Looks more modern now. Looking forward to my first ride to try out the navigation UI. However like you I cannot find the 'Find Scenic Routes' either. I'm sure all will be revealed shortly.
Hi guys... happy you like the UI so far. If you go to your routes, then tap the little + button, a menu will pop up. There's the 'Discover Routes' entry, which will bring you to the trusted "Find Scenic Routes' screen.
Did you see this menu before? Was it the new terminology "Discover Routes' that was unclear? If so, that's easily changed again.
Deleted user has reacted to this post.
Deleted user
Thanks Guido. Obvious when you know where to look.
I had that problem as well, but did find it.
IMO discovering Routes is a key feature of the app and should have a pronounced button, not just a drop-down which, evidently, could be easily overlooked.
Point taken...will add to list to make it more prominent and more discoverable
Richin501 and Bradiac have reacted to this post.
Richin501Bradiac
Quote from Guido on 01.11.2021, 09:13
It's perfectly well named, and in a sensible place once found.  I think I may just have failed to try that + button.
I agree it deserves to be more prominent.   When looking for it I sort of wanted it to be with the "show on map" layers, but can see that it wouldn't play nice with the others. Also thought it might have been a big "fake folder" at the top of routes even though that wouldn't be entirely consistent.
For what it's worth, I also had trouble finding it and also think it should be more pronounced. Also, when I looked for public routes in a certain area it told me there were too many to display and that I should add some filters. I added a filter to return only routes ranked 3 stars or higher. When I searched again the filter setting box wouldn't go away and it blocked the map until I pressed "clear filters." Then it would say that it found 23 routes but only displayed 4 on the map. I could see all the routs listed as a list, but only a few on the map. Is this normal? Absolutely love the app and new UI though and recommend it to everyone I know who rides!
There is no + sign on my screen.  I’m with many of the other posters - have been using Scenic for quite a while and am frustrated that ‘find local routes’ isn’t an option anymore. 🙁
You need to go to your routes through the side menu (tap upper left button to open side menu, then choose routes). Then you’ll see the + button like in screenshot a couple of posts up.
Wow, I had no idea this was a thing. Just found out from browsing the forum.
I will be honest I did not expect such a feature under the "+" sign menu! Glad I found it now as there are a lot of routes around me.
