Save to Current Folder
I have some folders besides the Favorites one.
Favorieten
ANWB
ARDENNEN
BOLLENROUTES
NORMANDIE
Noorwegen
and so on
Now when going into the Favorites folder and adding a new route, this is stored in the Favorites. When i go into any other folder, and click save, it selects ANWB. So i need to tap to the correct Folder. Maybe ad Upper() function not finding the correct folder and selecting the first one in the Array?
Hi Frank. It selects the folder you last saved into. This is done with multiple route imports in mind.
On my iPhone yes, on my iPad no. Could there a difference? I can Create an example video. 🙂
Hmmm.
I forgot to mention that this does not sync between devices. So, on iPhone it will be last saved to folder on iPhone. On iPad last saved to folder on iPad.
If that is not working on iPad I’ll take a look at that. No need for video.
Also… this was introduced in the latest version (3.06). Maybe your iPad is still on an older version? You can check in the App Store if an update is available: https://apps.apple.com/app/id1089668246
Accidentally deleted a folder and having difficulty recovering the routes.
was able to retrieve the public routes from the system generated folder “public routes” I have created.
Would be nice to have system generated folder that has all private routes.
I could create such a folder, but when you delete a route, it would be gone from that folder as well, so I don't think that would help in this case.
I might be able to restore the routes for you. Could you give me your Scenic nickname and the name of the folder in question?
