Routing Issue - Open Maps / Scenic?
Hi .. looking for some help with a routing issue in Scenic. Area is Westport, Ontario, Canada. Not sure if this is an Open Map issue or Scenic.
Screen shot of Scenic - won’t let me connect between way points 11 & 12.
Screen shot of Open Maps - same area circled.
Any help would be much appreciated. Thanks
It's calculating for me (see screenshots)
- Are your offline maps up to date? (Go to side menu > profile picture > offline maps. If there's an update there will be a big yellow bar at the top)
- What are your routing settings? Perhaps your routing settings are preventing from taking this road.
Thank you Guido. That did the trick. Appreciate your help.
