routing in France using motorway
Quote from Middelfrangge on 03.01.2025, 13:32Hi,
I had an issue in France using the highway/motorway from Djon to Avignon. On every exit Scenic wanted me to take the next exit and get off the motorway and back again. Is that a map issue or a scenic issue. The strange thing is that the exit was always no. 9 but it was always at a different exit.
See pictures.
regards
Thomas
See pictures.
regards
Thomas
Quote from Guido on 05.01.2025, 09:44This is a routing mode (and maybe map data) thing probably. I've noticed this myself too. Seems that the routing algorithm is a bit too strict with applying it's routing mode. Do you remember what the routing mode was for this route? Or, better yet, could you share the link to the route with me (if you have it saved)? Side Menu > My Routes > Select the route > 3 dots buton > share link.
Quote from Middelfrangge on 16.01.2025, 11:27Hi Guido,
had the same issue two days ago when driving back from Spain. It only occurs in France but here very often. I will have a look to openstreetmaps.org as I need to correct some map details anyway.
I will also send you a link.
Thomas
Thomas
Quote from Middelfrangge on 07.02.2025, 00:37Hi,
just a quick update. I have checked the OSM maps but did not find a failure……maybe its caused by the routing algorythm.
Thomas
Thomas
Quote from Michael G on 22.04.2025, 04:09Hi, that sounds like a map data glitch—Scenic might be misreading the motorway exits; a quick app/map update could help fix it.
Quote from Guido on 22.04.2025, 15:15Yes... this was fixed in an app update a few versions back.
