Routing errors (bicycle and farming routs)
Quote from StephanP on 09.05.2025, 01:18Hello Guido,
Since this year, the routes created have often been on wrong roads such as bicycle paths and farmland roads that are closed to traffic. Could you see if you can make improvements to this.
Thanks in advance,
Stephan
Traveling in Europe ๐๐
Hello Guido,
Thanks in advance,
Stephan
Quote from Guido on 09.05.2025, 03:24Hi Stephan,
This is due to your routing mode, probably. The slider towards "adventurous" will favor smaller roads and farm tracks. Etc. Bicycle only paths should be avoided though, so that's probably an error in the map data.
Hi Stephan,
Quote from Knuspermuesli on 28.05.2025, 14:56Hi,
I have exactly the same problem.
I chose "curvy" for my routes and here and then the route ended on "farm- or wood-only vehicle" "streets".
It also happened for recalculations when you hit a closed road.
You have to turn and hope that the navigation will choose a better route.
