Route planning via the Webapp
Is there a way to plan your route natively with the Scenic's webapp?  I like to plan my routes on my PC, then import them to Scenic afterwards.  I find Google's map creator a little cumbersome as I like to "draw" my routes on the map, rather than just type in destinations.
satmax and Addaxian have reacted to this post.
satmaxAddaxian
It’s on the roadmap to add a web planner. More info here: https://scenic.app/forum/topic/webapp-pushpins/#postid-3513
satmax has reacted to this post.
satmax
Quote from BVDucatiMult1950S on 08.05.2023, 11:31
If you want that capability now... Check out...
https://trips.furkot.com/
Furkot is well integrated with Scenic and will provide the functionality you are likely seeking. It's probably one of the most capable - if not the most capable - trip/route planner available (I differentiate "trip" vs. "route" for a reason). It will serve for both basic and advanced needs. Some comment that Furkot has a steep learning curve. I don't think so. Most of these types of application are very similar in how they function. Once you learn one, others are easier to pick up. Furkot's documentation is pretty good so one should be able to get off to the races with it fairly easily.
benedict63 has reacted to this post.
benedict63
