Route Navagation will not Start.
Quote from ChuckA on 06.04.2020, 09:36The last 2 routes I have downloaded and selected Start, have not started I think because the app does not recognize me at the Start Location. I have been in a culdesac both times and have ridden around trying to get it to register but without success.
Am I doing something wrong?
Is there a way to force the app to start navigation from where I am?
Thanks,
Thanks,
Quote from Guido on 06.04.2020, 10:28By default it will guide you from where you are to the start of the route. Once you select the route in the start screen a 'Guidance to Route' button appears above the 'start' button. There you can choose an option.
However it sounds like something else might be going on. Maybe Scenic is not getting a location from iOS. Does Scenic have access to your location? (iOS Settings App > Scenic). If it does, could you perhaps send me an email with some screenshots right after you tapped the 'Start' button?
Quote from ChuckA on 06.04.2020, 10:57Hi Guido,
Attached are the screen shots. I am likely doing something wrong.....
- my location services
- Start Route
- After Route Starts
- Driving Route, but no turn by turn directions
- Finish Ride
- Start Route
- Finish Ride
- You need to login to have access to uploads.
Quote from Guido on 06.04.2020, 11:03Hi Chuck,
I see the problem. This route is actually a track. For tracks you do not get turn by turn instructions. The track is just drawn on the map as a line for you to visually follow. If you'd like turn by turn navigation you'll have to re-import that route and save it as a route (i.e. don't use the 'save blue line as track' button, but use the 'save' button in the toolbar at the top).
Hope this helps?
Hi Chuck,
Hope this helps?
Quote from Guido on 06.04.2020, 11:05Have a look here for a bit more explanation on difference between routes and tracks: https://scenic.app/knowledge-base/offroad-dual-sport-trail-routes/
