Route Length Grows Substantially When Adding a Second Stop
Quote from Schuitema on 08.06.2021, 10:42As a new user of Scenic 2, I am often perplexed when creating a Route. I complete the task and am satisfied with the Route which contains a Stop. Later, I decide to add a second Stop that is along the same basic route as the original, e.g. in-line. This results in the length of the Route extending by as much as 75%. Naturally frustrated, I abort the new Stop by clicking Undo.
My workaround has been to add a VIA # in place of a 2nd Stop and then convert that to a Stop. The Route generator seems content with that and produces no additional distance beyond what I would expect.
Obviously I am missing some detail as I cannot imagine this behavior is normal at this late stage of Scenic 2 development.
Thanks much for the assistance and comments.
Quote from Guido on 08.06.2021, 11:52It sounds like the route is backtracking over itself if you add a stop. In other words, that the order of the stops is not correct. If this happens again, would you mind saving the route with the stop (and excessive length) and sharing the link to that route here (tap on route from your route list, then use 'share' button above the map preview)? Then I can have a detailed look and reproduce it.
Quote from Schuitema on 08.06.2021, 12:13I tried it a d made sure that the second Stop was added after the first Stop and on the Route where the direction of travel was directly down-road from the first Stop. The original Rout was like 43 miles. After the second Stop, which was in the line of travel was added the distance grew to over fifty miles!
I tried to Share it. Hopefully you can see it. The original was titled Night Ride while the modified Route with the added Stop had additional dialog in the title before Night Ride.
Quote from Guido on 08.06.2021, 12:16Sorry... I would need the share link. When you use the share button in the app, a link is created and a panel slides up from the bottom. In that panel you can choose 'copy'. This copies the link onto your clipboard. Then you can paste that link here, or, if you prefer, mail it to me. There is an 'email me' button all the way at the bottom of the support page.
Quote from Guido on 08.06.2021, 13:57OK... so, in the route you shared with me above, Stop 2 is added after via point 15. So basically, your route will now go from via point 15, to Stop 2 (=via 16) and then to the end point. That's why a lot of distance is added.
First a bit of background: A stop is also a via point, but a special via point. During navigation you will get an alert when you are close to a stop, while you won't get such an alert for via points. A stop has a stop number, but also a via point number (the small number in the magenta part of the marker). Via points (including stops) are visited in order.
So, knowing this, let's correct this route, assuming that you want to visit stop 1 immediately after stop 2 like mentioned above. Here's what you need to do to correct this route:
- Delete current stop 2 (tap on it and tap 'trash can' icon in the bubble that appears)
- Now, make sure the crosshair is in the location where you want to add Stop 2
- Then tap the bottom right button which I circled here:
- A message appears telling you to now tap the marker preceding the new stop.
- Since you want to visit new stop (stop 2) immediately after stop 1, tap the 'stop 1' marker.
- Now the route is like you wanted and distance has not changed.
I realize this is quite cumbersome and not so intuitive. In Scenic 3 this will be slightly redesigned making it easier to add stops and vias between already existing stop and vias.
I hope this explains. If not, please don't hesitate to let me know.
GuidoP.S. A remark about this route... The current version of Scenic has difficulty with routes that overlap themselves and crosses itself. When you start navigating this route you might find that parts of the route will 'disappear'. I.e. When you are on a stretch of road that's in the route twice, Scenic might think you are there the second time (while you are actually there the first time), removing the first part of the route up until that second time all together. This behavior is quite random. Sometimes it works just fine, and sometimes it doesn't. This is actually one of the most important reasons why I'm switching to a new map and routing provider in Scenic 3.
Quote from Schuitema on 08.06.2021, 18:44That worked perfectly. Indeed we are blessed to have somewhat curvy roads over hilly terrain and it is a most definite possibility that there will be some criss-crossing along the journey.
Looking forward to the new version and I am sure you are as well as it is obvious that you are gearing up for an overall more consistent implementation of your vision.
I also want to take a moment and thank you for all your time and effort to respond to my (and everyone’s) questions on the forum. We all are so fortunate to have Scenic and you and your team working diligently to make our motorcycle riding lives so much better.
Thank you for all you do!!
Quote from miros on 10.06.2021, 02:33Quote from Guido on June 8, 2021, 13:57I realize this is quite cumbersome and not so intuitive. In Scenic 3 this will be slightly redesigned making it easier to add stops and vias between already existing stop and vias.
on the contrary Guido, I think the idea of adding a via/stop explicitly after an existing one is quite neat and quick. I’ve seen other apps when you can only add at the end, and then have to move things around to place the new via/stop. That’s terrible.
