Route is different when importing from Kurviger.
When I make a map in Kurviger then import it into Scenic the route changes. If I turn on the show original route option then it shows correctly with a blue dashed line on the correct route. How do I get scenic to keep my original route when importing. Thanks.
First, make sure you use the "Send to Scenic" button on the Kurviger website. Do not export to GPX and then import that GPX into Scenic, because you'll loose some routing information that way. Here's how: https://scenic.app/forum/topic/imported-routes-from-kurviger-are-always-recalculated/#postid-2099
Still, you might see differences like you noted. Here is why this can happen and how you can correct it: https://scenic.app/help/strange-loops-while-importing/
Thanks for the reply. I have had better luck using Garmin Basecamp and exporting the GPX file then importing it into Scenic. How can I pay for a subscription not using the apple pay? I dont want to give them my info and have it stored so they can bill me at will. Been there done that.....;o)
At the moment you can only get the sub through Apple. There will come other payment methods, but that’s still some time away.
You can manage (and turn off auto-renewal) Apple subs quite easily: https://support.apple.com/en-us/HT202039
