route indication
Quote from jantenklooster@gmail.com on 03.09.2020, 14:15I would like it if the set route remains visible when I have (forced or accidentally) left it. I think that option was in the previous version. What I now regularly experience is that if I deviate, the route is recalculated. In itself fine, but at a certain point I see the red route line, for example, running straight ahead and a red route line connecting to it from the side. It is then not possible to see what the original route is and what the recalculated route is. That would be very easy to overcome by running a thin line through the thick red route line, which always remains fixed on the original route, and therefore does not change like the red line during recalculation. Now only a blue thin route line appears on the route driven. I have not yet discovered the use of that. In any case, it has no added value for me.
Quote from Guido on 03.09.2020, 15:15I added this feature back a few versions ago. Settings > Navigation & Tracking > Show Original Route.
The original route has the same color as the calculated route but it slightly transparent, so you will only notice the difference between calculated and original when you deviate from it.
