roundabout exit announcements
yesterday I recognized that the announcement which exit to use is different from roundabout to roundabout. I have in my setting road name „on“ and road number „off“ because road numbers of secondary roads in Germany are unknown and not called out.
Since the little number in the circle whichs shows the exit I shuld use, is a little too small for me with my Carplay display, I need the advice by the given announcement. So far so good, but at the first roundabout the information was „take exit to Ansbach“ which is ok because the city is called out on the sign. On the next roundabout the announcement was „take exit to St2523“ which is a roadnumber and nobody knows where that is (that‘s why I switche road numbers off) and at the thord roundabout I received the message“ take exit 3 direction to xxxx“
I would prefer to get always the exit number and even the road number would be added is o.k. but I have not found a setting for roundabouts.
thanks
Thomas
Hi Thomas,
Unfortunately, I can not change this. The audible and visual instructions are determined by the current map provider that Scenic uses.
Having said that, a big update is coming where I'm changing map provider from HERE to an OSM (Open Street Map) based provider. Keep an eye on our social channels in the coming weeks for more news about this. The big update, Scenic 4, is planned to be released on October 1st.
thank you! I will now wait for the next big update……maybe better since it seems it solves most of my topics.
I do like Scenic already very much and hope there are some improvements to make Scenic for me the perfect match.
Thomas
