Round trip - planning different from navigation
I planned the small tour today. The screenshot shows the planning and the tour that is then to be navigated. There is a connection in the navigation that is not visible in the planning.
Burkhard
The connection is from your current position to the route start. If you don’t want Scenic to guide you to the route start, tap the “and der route teilnehemn”, button.
Ah, I understand. The upper magenta dot is identified as my current position? But that wasn't the case. I was at the start/finish point when I started. That's where the flag is. That's where I arrived with the last navigation.
