Roll back route log.
Quote from Deleted user on 15.08.2021, 20:58Since the navigation system takes geo tracking breadcrumb recordings throughout the ride, it would be nice if we could adjust the ride’s start/stop points by moving the start time and end times along a timeline. For example, if I want to delete data from the end of my ride, I can drag a marker from the rightmost end of the timeline in a leftward direction. As in shorten the end time of the ride, the date/time appears, so I can better gauge the end. Additionally, as I slide the marker, the map will pan to show the collection point currently selected in bold. Once the Ned point or start points are selected, and the user clicks the save button, all data regarding those deleted items are removed. That means, my travel record will no longer count those miles in my stats.
this will make it easy to adjust a ride that has captured more than was intended for the ride.
Quote from Guido on 15.08.2021, 22:41I've had more request to adjust rides afterwards (specifically cutting out pieces). This feature is also on the list for Scenic 3.
