Road blocking feature and Carplay
does the road blocking feature not work, when SCENIC is connected to a Carplay Device?
I tested today without a connection to carplay and it worked as expected. Then I started my tour and the route on the Carplay device. Then I came to a blocked road, I took my iPhone out and selected "Road blocked" from the button menu and selected the blocked road, it became green, but the route wasn't calculated new, it only showed the green color on the road and leaded again to the blocked road.
Marc-Antón
This is unrelated to CarPlay. The road block feature sometimes works and sometimes doesn’t. I’m looking into this.
Ah, okay, good luck.
