Forum breadcrumbs - You are here:Scenic ForumUsing ScenicRide with scenic 4
Ride with scenic 4
Today I did my first ride with scenic 4.
And I only want to comment the drive ( ride) with S4
First.
You can ride with s 4. Of course. The zoom Function on 2D is good (3D will get later, and I like 3 D navigation). It works automatically in a range. I don’t know how it works. But you always get a good overview. So for me, it’s not a reason to change to another navigation. The navigation works. And the new map style is good too. The important things work. The Quality is also better to other motorbike navigation apps.
Second.
Up to now, it’s not the excellent Quality like Scenic 3.6.
Third.
some marks for Guido, to improve or develop S4.
- The Tap to control waipoints is smaller than scenic 3.xx. With your handkerchiefs it’s you must have good luck, to tap it at once.  It must be a little bit higher, but not further.
- on top left, the sign for directions or roundabouts is to big. It could be a half smaller and you see your way better, specially as 3D comes.
- on bottom in middle, you can see the route, which you drive actually, also name and Number, wonderful. But on top in the middle you only see the number of the road, after next turn. Better is to sign you the next town or city, which you reach.  Like signposts on road.
-  sometimes, the screen flatters, especially, when you leave your route.
- if you leave your route, a while, your route gone. Roundabout 10 seconds, route is back.
- and at last, when you rest for a while for a coffee or like this, your iPhone didn’t remember you, that S4 is active in the backyard. You cannot see it, like a blue sign on top left. Like google, scenic or Apple Card’s .
Guido, I hope it helps you a bit.
Frank, Erfurt, Germany
Thanks Frank... most of these will be fixed in v4.01 (next week... maybe tomorrow if Apple approves quickly)
Rest I will add to the list.
I forgot one thing.
Navigation on audio, for example with Sena, the last call comes too late, it comes when you have to do a turn or reach the roundabout. In Scenic 3.xx it was a little bit earlier. Roundabout 1 or 2 seconds before.
