Rerouting failing with the new version.
Since I did the upgrade to the latest version, if I go into a parking lot and go back on the road, it fails to continue the route. It wants to take me to the end. A 3 hour ride turns info 15 minutes somehow. This was not an issue with the older version. Is it just me, or is there some setting to fix this.
What version are you on? (You can see version number at bottom of the Settings screen)
3.05 should solve that issue (released Friday)
Guido,
I am on the new version. Maybe I need to delete the app and reinstall it?
thanks
If you are already on 3.05, an app reinstall won't help. I'll have to look into this in more detail.
Do you have the route saved by any chance? If so, could you share the route with me? (Select route from your route list and then select 'share' button below the map preview).
Here it is.
https://scenicapp.space/route/OlhBebVD
Thanks Danny... this is a bug probably. Where were you when you entered the parking garage? Somewhere between the start/end and via point 9? Or somewhere else along the route?
The issue happened before 1 which is close to 9. (Just south of 9) I only pulled into a parking lot and back onto the road.
Just to verify… when you entered the parking lot, where you still on the road that would also be taken at the end of the round trip? (The road that’s part of the round trip twice?)
Yes, the parking lot is on the return part of the trip just pass waypoint 9.
I also has this happen on a different route last week. I don’t think it’s totally related to just this route.
thanks
OK. Thank you for the details. I'll have a detailed look at it this week and hopefully fix it in an update for next week!
HI Danny,
I've been trying to reproduce this, but it just seems to work here on my side. At least during simulations of your route and making a detour on the first (and last) stretch. Perhaps you were still on 3.04 while riding this route and the app updated between the ride and you checking the version number. Could that be possible?
Would you mind giving this another try if you get the chance?
I'll try as well on my side with a similar situation in my area, but it would help if you could do this too since every situation can be a bit different.
Thanks and cheers,
