Recalculate route without stopping ride tracking
Quote from CS_Ulf on 22.06.2020, 02:25I'm using Scenic since a couple of days and I'm really impressed.
What I miss is the possibility to recalculate the route with other parameters (e.g. modus fast instead of curvy) or even stop the current route and create a complete new one.
The only way I found so far is to stop the ride and start from scratch. But this means that I have several rides for the day (and thus the track for the day is split in several files).Is there a possibility to solve this Problem?
Thanks, Ulf
Thanks, Ulf
Quote from CS_Ulf on 22.06.2020, 03:45Oh - I jst saw that the answer was probably already given in another post "Assembling Rides" a couple of hours ago.
Cheers, Ulf
Cheers, Ulf
Quote from Guido on 22.06.2020, 11:40Next to the 'assembling rides' feature I am also planning to make it possible to change to another route (or recalculate the route) during the ride (so that you won't have to end the ride). This will probably be for next season though.
Quote from RichardW71 on 29.05.2023, 12:16Hi @guidomm! I really enjoy your app, it is so easy to drive a route and track data. I've tried so many other apps but yours is by far the best. The only thing I really would like to do is to start another route while I am tracking. I already see that you were planning to incorporate this feature - will it be in the app in the foreseeable future? Thanx for all the effort you put in the app and the community.
Regards/Groeten,
Richard
Regards/Groeten,
Richard
Quote from Guido on 29.05.2023, 13:30It's already possible but it's a bit hidden:
- While navigating, tap the bottom bar (where you see time/distance to destination)
- In the panel that slides up, choose 'Pause'
- Now choose 'To main screen'
- This will take you back from the main/start screen where you now can select another route or destination. And then you can tap the 'Resume Ride' button.
Quote from RichardW71 on 29.05.2023, 13:58Hi @guidomm,
Yes! Exactly what I needed. Works like a charm. The only thing that differs from your instruction is that after i've chosen another route, in the route-details I clicked 'Navigeer' and it returned to the map. Then there was no 'Resume Ride' button anymore (there was when I paused the track), instead there was the 'Start navigatie' button. It worked, the tracking continued.
Thanks for your quick reply.
Richard
Hi @guidomm,
Richard
Quote from RichardW71 on 06.04.2024, 12:20And in version 3.5 it is nicely integrated in the popup menu, available while navigating (while pausing might be even more perfect!).
Tnx
Richard
Tnx
Richard
Quote from RichardW71 on 13.04.2024, 09:27Unfortunately, even though the dialog box stated something different, the tracking feature did not continue recording correct after switching, changing or cancelling the route. When I finished my ride today only the last few km’s were recorded. Are there known issues with the tracking-feature in version 3.5?
Richard
Richard
Quote from Guido on 13.04.2024, 09:33I didn’t get any other feedback on this so far. Are you using scenic in the background (or iPhone locked) perhaps? If so, scenic requires ‘’always’ location access. https://scenic.app/help/not-tracking-entire-ride-pause-resume-tracking/
Quote from RichardW71 on 13.04.2024, 10:01Hi,
Thanks for your quick response, I appreciate that. Location is set tot ‘always’, so that should not be the problem. Since it is an important function for me, I will do some testing later this week(end) and see what happens. If possible and if reproduced I will send some screen-recordings.
Richard
Richard
