Put a tank stop to a planned route
I have some difficulties with inserting a tank stop to an existing, planned route. How is theright method to find e.g. a gas station around the route and make a navigation to it?
I tried it and got some strange routings.
Thanks and regards
Marc-Antón
Hi Marc-Anton,
I'm assuming you want to do this while navigating? If so, while navigating, double tap the map to go to edit mode. Then center the map to the location where about you want to add the gas stop. Then tap the search button at the bottom and select 'fuel'. The search result will contain all gas stations in a 10km radius of the map center. Per default you get a list, but you can also choose to show the results on the map by tapping the 'map' button on the top right. When shown on the map, you can simply tap a search results and choose to add it to the route.
Hope this helps/explains?
Bradiac has reacted to this post.
Bradiac
Thanks, Guido, this worked for me.
Marc-Antón
I’m going to have to use this method on my next long trip. The problem with asking Siri, which uses Apple Maps, is that it has no idea which direction your route is headed. So it will give you options that are way off route, or gas stations you’ve passed miles ago.
Thank you Guido. 👍
Really need to be able to search and add fuel, restaurant, and hotel stops on the go in Carplay.
Quote from Farmwinger on 18.09.2022, 20:21
I will add that to the list. Until that time, the workaround is to disconnect from CarPlay temporarily, add the stop to the route as explained above, and then reconnect CarPlay. I know this is not ideal, but perhaps it will work for you for the time being. Cheers, Guido
I would also like to plan the route accordingly with a tank stop. So the target for the round or route is 390 kilometers and after 200 kilometers a gas station.
Hi Micha,
I will add this feature while I’m doing the migration to the new HERE map framework during fall/winter.
mfeske and iSilentP have reacted to this post.
mfeskeiSilentP
