Public Route Share Privacy
Quote from NH_Moto on 02.11.2023, 02:52And option to set a default route start that is not your home or something that starts the route on the first major road away from your home.
I would share more routes but I don't like sharing my route starting at my home.
Quote from Guido on 02.11.2023, 06:37Perhaps I'm misunderstanding, but wouldn't that be very easy by placing the route start marker a bit away from your home, on a nearby road?
An important thing to know is, that when you select a route for navigation where the start point is not close to where you are, Scenic will include navigation from wherever you are to that route start too. Give it a try... create a test route that start, a few miles/km away from your home (at a restaurant / meeting point for example), and then select that route for navigation. Scenic will navigate you to the start point of that route and then start the route navigation.
Quote from Traxx on 04.02.2024, 07:31When planning a route that is all fine and good. But say you are just going on a “spur of the moment” ride with no route and are just tracking. I am pretty good at remembering when I am leaving home or work or what ever but when arriving.
I know it is possible, since it is offered elsewhere and basically it gives you the option to select an area that is not tracked.
Anyway the app has been great to me for years across many Motos and Miles. Keep up the good work.
Quote from Guido on 04.02.2024, 10:56I’m not sure I understand. You can only make routes public (by default they are private, only if you choose it will be public). Recorded rides are never public.
If I misunderstood please let me know.
best regards,
best regards,
