Problem with volume when navigate
hi
I hav problem with the volume for direction, I try to set it up whit control in the app, helmet and telefon!
But it’s reducing it self at once, in front of my eyes
That’s very strange. Are you see this is a Scenic issue? What happens if you try with other apps?
Some helmet com systems adjust volume based on surrounding noise. Almost sounds like volume down button is stuck for some reason.
Hi
I have no problems with other app. And It don’t matter if I got it paired whit helmet or not. It’s the same on my IPad.
I can post a film if you want?
A film might be helpful yes.
IMG_4369
OK  I think there might be a misunderstanding.
The orange slider you see at the top is to indicate the duration until the menu disappears automatically (so that you don’t have to manually close the menu while riding). It resets every time you tap a button in the menu
The volume slider is the one you see appearing at 22 seconds and 26-28 seconds of the video. I don’t see that decreasing.
Could that be it?
Ok
I hav misunderstood
but I can not get any out of the speaker I helmet, I did last year, now I just her som electronics sound
I will keep trying 😄
I see that your premium expired in October. If you are not premium there is no voice guidance.
If you still have the subscription maybe it did not auto-renew. On that case could you try following:
- open side menu
- Tap profile picture
- Open ‘premium & offline maps’ section
- Tap ‘premium’ row
- tap ‘restore yearly subscription’
