Forum breadcrumbs - You are here:Scenic ForumUsing ScenicPossible POI group bug
Hi Guido, I have 5 POI groups in Scenic since Version 2, that I update every time I can. 2 of them are 2 different speed cameras lists that I periodically download from a group that keeps them up to date. To do this I download a CSV file, I convert it in a GPX file with this format "41.751820,13.816450,Abruzzo - Valico di Forca d'Acero 1551m" and upload it via the Web App.
This always worked flawlessly but now that I tried to do it on Scenic 3 I think I found a possible bug, or maybe my lists are too big, I don't know.
the two lists have 6829 pois the first and 7409 the other, they were a couple hundreds smaller each one before the "update". They seem to cause the app to freeze (or at least slow down incredibly), and it crashes after a couple of seconds.
Do you think this could be a bug, or is there a limit in the lists that I surpassed? The lists worked very well before on scenic 2 on an iPhone 7 (now I use a 2020 SE model with more memory, so I don't think this is the problem).
Let me know if I can help you diagnose the problem, or if I did something wrong. Thank you very much!
Could you try downloading the latest version through the App Store please: https://apps.apple.com/app/id1089668246
It was JUST published (like 45 minutes ago) and addresses this bug. It will be released over a 7 day period so most likely you are still running the ‘old’ version v 3.02. By going to the App Store you will force the update to v3.04
Neo9686 has reacted to this post.
Neo9686
That was fast! 😀
Thank you Guido, it seems to work flawlessly as it was before. Thank you again for your work.
