POI visibility depending on the zoom level
Hey Guido,
first of all, I like the advanced selection of POIs in scenic  and also the possibilities  to change the size of the POIs in the map.
Now I recognize that the visibility of the POIs depends on the zoom level, what is not easy to handle. Actually I have a view on the map where on zoom level 2km I see some petrol stations. If I zoom to 1km a further petrol station appears, if I zoom to 500m some of them disappears again. And then I have to zoom in  deeply to see the other POIs like supermarkets and ATM machines.
Is this on purpose? It make the use of POIs much harder than expected as now I have to zoom in and out randomly to check if there is no POIs hidden. The same on POIs like ATM machines, why do they only appear on a higher zoom level? If  I am looking in a larger area, the finding of an e.g. ATM  machine is a challenging task.
Greetings Frank
Hi Frank,
Improvements are on the way for that. Working on a redesign for the fall of this year.
GruenesZimmerhuhn has reacted to this post.
GruenesZimmerhuhn
