Option to add via and stop points
Is it possible when you look at a saved ride to show the original via and stop points from the route (if any route has been used). Most probably the ride is not linked to a route, so in this case an option to choose the route will do the job.
The other thing is an option to add also all points there the nav entered in ‘waiting’ mode and required resuming. This will be helpful to see places where you really have stopped because os something (good view fox example). This way you will not need to go over the whole ride and try to find this spot (this is very time consuming, especially when using this road for the first time).
In fact the route is linked to a ride... so this should be possible (if the route was not deleted obviously). I'll add it to the list.
Regarding your other point... currently there is some limited functionality around that. If you take a picture from within Scenic during your ride (tap bottom eta bar and then the camera button) the moment and location of the picture is saved. You'll also be able to see thumbnail-pins of those pics on the map (currently not in the app but if you use the 'share' link you will be able to see those thumbnail-pins. It's still on the list to also add these pins to the map preview and when viewing the route or ride full screen.
botzko has reacted to this post.
botzko
Forgot to mention that it's also on the list to expand this 'picture' feature with just some easier accessible 'thumbs up' / thumbs down' button. So when you pass something you can quickly mark the spot (if you have touch enabled gloves obviously). Later, when not riding, you can add comments to those places.
botzko
