Opening Route Timeline turns off the Save button
Guido,
Loving the update!
I am having issues with the Save button being grayed out even when there are changes to save.
Here are the steps:
  • Create a new route and save it
  • Open that route and make an edit so the Save button is active.
  • Open the Route Timeline, then close it.
  • The Save button is now grayed out and you cannot save. And if you hit cancel, it doesn't ask you if you want to save changes so you lose everything.
  • Make any change to the map (just move a waypoint) and the Save button is active again and Save works as it should.
  • Before you save, open the Route Timeline again and the Save button goes gray again.
This only seems to happen on routes that have been saved and re-opened. This happens on routes created prior to 3.51 and after. When creating a new route, before you save it, this doesn't seem to happen.
Let me know if you need more details/testing or screenshots.
All clear. Thank you for the details. Will fix for the upcoming update.
Stresspuppy has reacted to this post.
Stresspuppy
