Forum breadcrumbs - You are here:Scenic ForumScenic Feature RequestsOld Map
Old Map
When i first started using Scenic it would show on the main map all the roads i've ridden.  Is there a way to view that map again?
Yes. You can enable that "layer" through the 3rd button from top left.
Found it.  Thanks!
