Forum breadcrumbs - You are here:Scenic ForumUsing ScenicOffline Navigation
Offline Navigation
ím using scenic V4.27. Today i was in belgium without any mobile data. All offline maps were up to date but offline navigation doesn‘t work. It only shows „ Calculating Route“ but this never ends. So i hat to quit Scenic an to restart.
This behavoir is even with predifined Long routes as with short distances.
Please take a look at this.
Regards Ingo
Hi Ingo,
That's weird. I tried to reproduce myself (by going to airplane mode) and then selecting a pre-defined route in the area for which I had an offline map installed. It calculated without problem.
Could you perhaps share the link to one of the routes with me? (Select route from route list > 2 dots button top right > share link).
Thanks and best regards,
Yes of course:
https://scenicapp.space/route/JAqVjGWU
the problem exists after travelling from  stop 1 to stop 2 where there was no mobile data.
but we have to admit that after stop 1 the app was closed due to a museum visit.
even a restart of the iPhone was not successful.
Merry Christmas
Ingo
Quote from ipro on 24.12.2025, 04:27
I wonder - when I stop for fuel, a rest, food or whatever I leave Scenic running in the background. It auto-resumes when I get back on the bike and start riding.
Where I often ride there is no mobile service, so the off-line maps help a lot in that regard. I check before any major ride that the maps have been updated and are active.
Hi Igno,
I see that the route crosses through Germany, Belgium and Luxembourg. Just to double check... do you have all these regions downloaded to your device?
I'm asking because, when a route needs to be recalculated, it's recalculated completely (from where you are until the destination). So, if, for example, the Luxembourg map is missing, it won't be able to calculate (because stop 4 is in Luxembourg).
On top of that there is a bug in 4.27 where the spinner doesn't disappear when this happens. This will be fixed in 4.28 so that you can at least still see the map with the 'uncalculated' route.
I just checked. Yes, all offline maps of these county’s are downloaded.
But even if they are not downloaded I admit there is a hint instead of doing nothing 🙂
Ingo
