Offline Maps will not finish downloading iPad
Quote from Dragon74 on 14.08.2022, 02:43Maybe I can get some help here. I downloaded my offline maps on my iPad but it will not “finish”. The circle is complete and looks done, but it stays in the Not Downloaded category.
Everything is fine and works great on my phone, it is just on my iPad.
Quote from Guido on 14.08.2022, 03:23This happens sometimes, but haven’t been able to figure out why to be honest.
Could you try closing Scenic by swiping up in the app switcher and then reopening? If you reopen, what state are the downloads in at that point?
Quote from Dragon74 on 14.08.2022, 04:31Closed the app. Restarted my iPad. By the status, looks as if it’s all downloaded, just won’t finish/install.
Quote from Guido on 14.08.2022, 07:03This is not good. It means that it won’t recognize Germany as downloaded, and will go online for calculations and showing the map. Best is to logout of scenic and log back in again. Then redownload. I recommend to keep scenic foreground while downloading… and if possible make sure your screen doesn’t go to sleep. That’s the fastest (downloads are slower in the background) and most reliable way (less chance of interruptions / connection drops).
I’ll take a look at why this happens and make adjustments if possible.
Quote from Mex on 14.08.2022, 08:58Hi folks.
Had this issue on my iPad as well.
My workaround: Stopped all downloads. Downloaded one country, and all other step by step. Worked really fast. Never download several countries at once.
Sometimes updating the maps is really slow. Since 3.12 updates work really fast.
Maybe this helps.
Regards, Mex
Hi folks.
Maybe this helps.
Regards, Mex
