Offline Maps on smartphone due to bad network conditions
Quote from Scimitar on 28.08.2022, 07:16Hi,
I just use Scenic during a three weeks motorcycle trip with my K1200GT through Scotland. Hardware was an iPhone SE 2nd generation mounted in a bag with a folio on the front side and an iPad mini 6th generation for the planning sessions.
Planning went well except for the missing of several petrol stations in rural Scotland in the map (which made me sometimes quite nervous). During the tours I encountered several problems with the navigation system. Sometimes the screen of the iPhone went completely blank, which is possibly caused by a heat issue in the very warm weather. Biggest problem was a completely wrong route, which leads me through very small agriculture roads in circles and sometimes get even dangerous. The only way to break out off the wrong route was to completely give up to drive by Scenic and choose a direction for yourself.
After a while (around 30 minutes or so) Scenic does a route correction and the rest of the tours went fine. As far as I could reconstruct the problem it seems that it was caused by a bad network connection. The system sometimes was very slow to make a route correction an leads me in a completely wrong direction.
So my most wanted feature (beneath an Android version, so I could replace my iPhone with a cheap outdoor smartphone) was the possibility to download the complete map of a chosen country, so I get more independent from the quality of the cellular network.
Quote from Guido on 28.08.2022, 07:38Don’t think this is due to bad network connection. Scenic uses offline calculations (assuming you had the Scotland offline map installed).
Rather it’s mostly likely a missed via point or via point that was you did not get close enough of.
Have a look at your detour behaviour settings and this thread: https://scenic.app/forum/topic/reroute-at-detour-not-working/
Also, make sure you are running latest version. (3.14 at time of writing). Check App Store for an available update: https://apps.apple.com/app/id1089668246)
